Old 07-11-2018, 10:13 PM   #17
Geof3
If you haven’t directly looked at your engine (which I assume as you mentioned you did not check the level) then you aren’t seeing the overflow potentially. It drops straight down on top of the engine into all manner of nooks and crannies. Check your fluid, look over the top of your engine to see if there is any accumulated there. Refill with Pentosin, there really is no reason not to and go. I have an underdrive pulley, and my PSP has no issues currently. Keep in mind a UDP requires a bit of engine case modification as well, plus some pretty serious torque on the bolt. If you do one, do a solid one for strength. You can’t see the thing anyway so getting a styled up funky one is pointless.
