Also check for wheel bearing play. Try jacking up the car and checking for wheel play, you don’t want to push failing wheel bearings too far on these cars. The aluminum hubs are soft and the bearings can spin in the hub when they fail, if this happens you’ll need a new hub as well as a bearing.
1997 Boxster 4.2L Audi V8 Bi-Turbo
2003 911 C2
NASA HPDE Instructor
