Yes, at the front I 'threaded' the spring off the piston. You do not need to fully 'clear' the top of the piston on the front, so you don't need to get the strut terribly low.
That was actually on a 987 Cayman, but it's basically the same car with the same suspension design.
Rear is probably the same in that regard. I think it would mainly be a question of whether you can get a gun onto the nut on top of the strut...
