Old 07-09-2018, 02:51 PM   #1
Lowski
It looks like I have solved my P1128 & P1130 problems. Below is what I have learned and figured out along the way. Sorry for the long post……
I noted originally along with the P1128 & P1130 codes the car wouldn’t run very well. In retrospect I believe this was self-induced due to a clearing of the codes and then immediately trying to drive the car. I have now learned when clearing faults with a scan tool you need to let the car idle and learn the new values before trying to drive it. I know some of the e-gas models have a key on and off procedure to help facilitate this.
During my troubleshooting I assumed I had a vacuum leak. Besides reading all the various posts from others that found vacuum leaks I didn’t have anything concrete telling me I had a vacuum leak. But off I went…….
I bought a smoke generator to find the leaks. I ended up buying one of the homemade examples made out of a paint can on eBay. For $70 bucks shipped it was quicker and easier then sourcing all the parts and building it. It works great for how simple it is. My only criticism was the wick choice used by the builder. The builder used a fabric wick out of an oil lamp. The wick burnt up completely after about 10-15 minutes of use. A tiki torch works just as well and holds up a lot better.
I smoked the engine on three separate occasions. The first time was a bit of a learning curve of where to hook it up and I didn’t end up finding anything. The next two times I hooked up to the rubber hose that attaches to the right side of the throttle body. I believe this hose is part of the secondary air system. On the next smoke session I found a leaking oil cap. Changing it with a new one made no difference. I smoked again and found a small leak in the accordion section of the oil fill tube. Changing it with a new one made no difference.
Additionally during smoking I always removed the MAF as not to foul it. Before reinstalling it I cleaned it with MAF cleaner. It ended up making no difference any of the times.
During the above troubleshooting I ended buying a Durametric off eBay. I started looking at my mass air flow sensor values. At idle my output voltage was around 1.3 - 1.4 volts and my air flow around 12.5 - 13.5 kg/h. Very close or within DME 5.2.2 setpoints of 14 +/- 0.1 volts and 15 +/- 1.25 kg/h. At face value it looked like my MAF was ok.
At this point I am started to get frustrated. No obvious vacuum leaks and the MAF looks ok. The next things on the list are fuel related. I figured this would be a good time figure out what these fuel trim things are all about. I started with the following YouTube videos. I found them very informative and really helpful to explain what the values mean.
Part 1: https://www.youtube.com/watch?v=5WnM_NsOtd8
Part 2: https://www.youtube.com/watch?v=cARQ0jZZ4Qc
With my new found knowledge I excitedly hooked up my shiny new Durametric and ran promptly into a wall. Durametric for the DME 5.2.2 does not report short term fuel trims (STFT) and long term fuel trims (LTFT) like a generic OBD-II tool. It does report adaptations for the “idle” range (RPM 1700 and below) and the “cruise” range (RPM 1700 and above). These values are listed as TRA/TRA2 and FRA/FRA2 respectively for the DME5.2.2. Other versions may have different labels for the same thing.
The DME 5.2.2 setpoints I found in workshop manual online are:
FRA Bank 1 = .96 +/- 0.03
TRA Bank 1 = 0 +/- 0.03
FRA Bank 2 = .96 +/- 0.03
TRA Bank 2 = 0 +/- 0.03
I have also seen some online references to TRA being a value of 1. I don’t know how current my manual is, but it’s all in the ballpark.
My Durametric gave me this values in this general range:
FRA Bank 1 = 1.29
TRA Bank 1 = -.29
FRA Bank 2 = 1.29
TRA Bank 2 = -.22
First thing I noticed was the negative TRA values. The car is running rich and taking fuel away at idle. If I had a vacuum leak the TRA should be positive. To validate my theory I took off the oil cap at idle and over several minutes I watched the TRA values change from negative to approx. 0.2 – 0.3. The workshop manual provides oil cap off TRA values and mine were in the ball park. Putting the cap back on made the TRA values swing back to negative.
Knowing I didn’t have a vacuum leak I wasn’t sure how to explain the negative TRA values and the positive FRA values. The car is adding fuel at cruise. Maybe something in the fuel regulator or fuel delivery, but that does that jive with the fuel removal at idle.
I did some more internet digging and found a few forum posts of Boxster owners with the same codes and similar FRA &TRA values. A new mass air flow sensor fixed their issues. After some hand wringing I decided to put in the new $190 MAF sensor and see what happens.
I cleared the codes with the Durametric and watched the FRA & TRA reset to 0.98 and 0.0 respectively. As the car idled the FRA values held steady at 0.98 as expected and the TRA values dropped negative to previous negative values (unexpected) and then after about 3-5 minutes they increased and steadied at -0.03 which is right in the acceptable range. I took the car for a drive at this point and the FRA values hovered right around the 0.99 – 1.0 range.
I have driven the car a few times now for about 50 miles (highway and around town) and the values have steadied at:
FRA Bank 1 = 1.0
TRA Bank 1 = -0.1
FRA Bank 2 = 0.99
TRA Bank 2 = -0.03
No check engine lights yet and I passed my emissions exam today. So I am cautiously optimistic the new MAF sensor has done the trick. I am a little worried about the TRA bank 1 being a bit higher than TRA bank 2. With the old MAF sensor it was higher too. I wonder if I have an injector on that cylinder bank going bad.
Lowski is offline   Reply With Quote
