Old 07-08-2018, 04:47 PM   #3
kosborn
Thanks for the help.....great response
I do notice when I open the door I can push the window down..the same distance that it would lower if working properly....I also tested lowering the top to see if the window would lower....it lowered, not as far as the drivers door and I could push the window down....
Do you think that this indicates a bad microswitch or window regulator?
kosborn is offline   Reply With Quote
