Thread: Rear End Noise
Old 07-07-2018, 11:33 AM   #1
gabedrummin
gabedrummin's Avatar
Rear End Noise
Rear End Noise while cornering hard. Thought it was from the axles but they have been replaced as has all suspension and coil overs. Will only do it while turning left or right while the gas pedal is pinned.So I guess its the differential ? The car is at the shop getting a new motor installed so its a good time to check it out. Anything I should look for ?Thank you all so much..!
gabedrummin is offline   Reply With Quote
