Old 07-06-2018, 06:52 AM   #16
JFP in PA
If it is the Brembo kit, the rear rotors are Brembo's, just not any that you can buy as the e-brake area inside is machined differently to compensate for the base brakes. The calipers are stock S calipers, nothing more, with spacers to get them at the right distance from the axle centerline to obtain proper pad contact because you are using them on the wrong hub carriers for them to line up correctly.
And no, I have no idea where you can get replacement rotors. You can contact Brembo USA, but they would have to make them up for you, which (if they will actually do it) is not going to be cheap. Be sure to let the board know what you come up with, as I am sure you are not the only one facing this problem.
