Old 07-05-2018, 02:10 PM   #1
Leebherron
Fan Noises
If the fan sounds makes a flapping noise it is probably foam that lines the fan box. The foam when new and fresh was used for sound insulation !? It can get stuck in the fan blades. It may blow out your vents, if set the fan on high for a while. If not, you must disassemble the box to get it out. :ah:
Leebherron is offline   Reply With Quote
