Old 07-05-2018, 12:38 PM   #4
porscheboxster987
Originally Posted by ExplorerLyon View Post
Sometimes mine stops 1" before full close. The fabric on the sides is not properly in the channel preventing full closure. Check that the fabric is not binding up in the side channels.
Went out to check the car a few minutes ago, and sure enough, the fabric on the sides were not properly in the channel; the rubber on the canvas’ sides seem to be overhanging the plastic window rim rather than fitting in. In other words, the edge of the canvas top isn’t tucking into the plastic frame correctly upon “closing.” Not sure if that makes sense. I will try to fix this and see if it solves the problem. Thank you.
porscheboxster987 is offline   Reply With Quote
