Old 07-05-2018, 08:53 AM   #14
JFP in PA
Brembo made the rotors for this kit, but never made any replacements because the kit was not a big seller. The rear's are unique because they are internally machined to accept the base e-brake, which is totally different than the S car's. And before you ask, no, you cannot retrofit the S e-brakes to your base car without also swapping out the carrier hubs, etc.
I do not believe you can just remove the rear caliper spacers and use base rotors as a replacement, you would need to get base calipers as well.
