Originally Posted by thom4782
I had the same symptoms. Found a broken wire inside the steering wheel assembly. Once fixed, the horn worked.
That’s what I can’t figure out. There is only one harness/hookup. The harness has 2 grounds, I plugged into one and that was the loose connection, but yet the horn worked with the ignition off. Very strange.
