Old 07-02-2018, 09:43 AM   #4
AZ986S
AZ986S's Avatar
This is interesting, as I have been going the other way.
I started out with Royal Purple Synchromax because I have had excellent results in other vehicles. It worked fine. After 2 years and 30 HPDE events, I drained and refilled with Porsche Fluid to see if there is any difference, knowing that it is the most recommended fluid for these transaxles.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
