Old 07-01-2018, 07:56 PM   #5
rexcramer
1997 Tip, 2018 Macan
rexcramer's Avatar
+1 and then some. Water can't be compressed. If it gets into a cylinder on the way back up, you will break a rod and or the crank, i.e. grenade'd engine squared.
Originally Posted by Geof3 View Post
Time for a tear down. If you are still loosing oil (with no obvious external leaks) you are chasing your tail trying to flush. You have an internal problem. Best to get it solved before you grenade the entire engine...
