Old 07-01-2018, 01:34 PM   #3
JFP in PA
Originally Posted by Lew View Post
Have had only one P0139 on a quick scan with the Durametric and cleared it. It has not come back in a few weeks. I removed the MAF and cleaned it with the CRC cleaner a while back. New plugs at 30K and at present just 3k on them. I may have a vacuum leak somewhere. Going to look especially at the foam rubber around the Air Cleaner box. That's about it JFP.
If the P0139 was real, you have an O2 sensor aging out on bank 1-3, which is one of the tools the MAF uses to try and control the mixture. If you also have a vacuum leak as well, that will also drive the MAF nuts.
I would use your Durametric to watch both O2 sensors on bank 1, to see if their voltages are inline. Could be the root of your issues.
