Originally Posted by BYprodriver
Most important thing is to jack up the car evenly as possible & level so that the triangular sheet aluminum plate in the rear comes off & back on easily. If you don't you will have to do a lot of prying to install it.
I’ve never been able to get mine on and off easy even when lifted straight up.
I’ve found running a ratchet strap through the rims and a slight bit of tension to pull them together and it drops right off. Same putting it back on.
Don’t go mad on it - just a little bit of tension.
Sent from my iPhone using Tapatalk Pro
