Thread: Go Air Horns!!!
Old 06-30-2018, 07:27 PM   #3
rick3000
There Is No Substitute.
rick3000's Avatar
I installed an airhorn after a similar encounter with a semi-truck on a freeway onramp. If you are taking your bumper off to clean the radiators, splicing an airhorn onto the existing horn wiring and wiring it to the battery isn't very hard. I recommend a compact one, especially if you have a third radiator. Plus, if you leave the existing horns you can still beep someone before the airhorn triggers.
