Old 06-29-2018, 05:01 AM   #2
obthomas
With the window down try to adjust the window to fit. A few mm above the roof seal.
window up... measure ...window down ...adjust... repeat until you get it about right. both adjustment screws should be in contact with the stops when the window is up.
Then:
With the window down close the door. Roll the window up and hold the switch in the up position for about 5 seconds. This teaches the motor what it needs to know for limits. You will need to do this 5 second switch thing every time the battery is disconnected.
Remember, always have the side airbag connected when the ignition is turned on or you will get an airbag code that not all scanners will clear. Good Luck. Hope this helps.
obthomas is offline   Reply With Quote
