Old 06-29-2018, 02:03 AM   #1
juliof16c
Window Height Adjustment 03 Box S
I just replaced the window regulator and it works ok. I think the window is too high and trying to adjust it down. It moves in the correct directions at the correct times but too far. Window moves up about 80mm up/down when opening/closing. I can't get the door latch to fool the car. It snaps, as if closed, but the window doesn't move until it's really closed, then works. Since the window is not up all the way I can't get to the torx screws on the bottom of the door to adjust. What else is going on that the door is not fooled it's closed. I checked all the measurements I could and they seem way too much and need to be adjusted down. Thanks for any help.
juliof16c is offline   Reply With Quote
