Old 09-10-2006, 07:29 PM   #2
ukchris
Jim:
The map light is independant, there are three cables going to it, a switched 12v that comes live when the door opens, a constant 12v used for the switch and a ground. The other option would be to wire straight to the bulb contacts then you could have the footwell light up whenever the map light was on.
Josh:
I didn't use a switch at all, I really don't see the benefit to be honest. It would need relays and all sorts of stuff to make it work and I can't envisage a case where I'd want to turn them on with a switch anyway. They come on when the door is opened and stay on with the other cabin lights, when they fade so do the footwell lights.
ukchris is offline   Reply With Quote
