Old 06-27-2018, 11:04 AM   #22
brianmch
No surprise you have chocolate milk in the oil cooler which contains the same oil that's in the pan.
I'm betting your motor has an internal issue causing the intermix.
I would have it hauled to a real mechanic who can determine the exact issue. Your local POC members should be able to provide you leads to a competent wrench unless you're comfortable dropping and rebuilding yourself.
brianmch is offline   Reply With Quote
