Old 06-25-2018, 05:28 AM   #1
78F350
Motorist & Coffee Drinker
78F350's Avatar
I had a similar problem with a bolt on a VW transmission. I tried heat, cold, penetrating oil, wax, and welding a nut on. In the end I drilled it out and ran a tap in the hole to clean out the threads. I wished I had gone ahead and drilled it sooner.
Grind off the end and use a good set of Cobalt (or at least Titanium Nitride) drill bits and make the bolt go away.
