Old 06-24-2018, 01:57 PM   #1
JFP in PA
Originally Posted by soxfan1966 View Post
It was suggested to me take the slave cylinder oyt to lube the end of it and spray some white lithium grease in the bolt holes to try and quiet a sqeal in the throwout bearing.
So I'm trying to confirm having the car on a lift would make removing the part easier before I try it.
I really would not be spraying ANY type of lubricant into the bell housing, it is going to end up on the clutch. The throw-out bearing is sealed, you could submerge it in oil with out any affect. If the throw out bearing is making noise, it is time to take the car apart and fix it properly. There are no short cuts here...……….
