Old 06-24-2018, 12:47 PM   #11
particlewave
Originally Posted by Terryg View Post
Am I missing something, why cut into the box, why not drill straight through? It's not like you could miss the pipe internally.
Either way, you'll have a hole that needs a plate welded on. Cutting a larger hole would certainly make the work a bit easier.
You're not going to drill through the body and pipe in one pass, anyway. You have to drill or cut a large hole through the body, then center punch the pipe so the drill bit doesn't just slip off of it.
