Small, lightweight, and no maintenance required! Element Fire Extinguishers pack all the power and coverage of a full-sized fire extinguisher into a package small enough to fit into your glovebox.
Element is a manual, portable fire extinguisher which utilizes a specialized aerosol mixture to safely and cleanly put out most major types of fires.
Suitable for A/B/C/K fire types, Element's mixture of Potassium Nitrate, organic oxidizer, and plasticizer resin is a non-toxic, environmentally friendly, and non-corrosive.
Unlike a dry-chemical fire extinguisher that uses solid powder to smother a fire until it's out, the aerosolized gas from Element's extinguishers attaches directly to the surrounding oxygen molecules, robbing fires of their fuel source.
Features:
50 seconds of discharge: more than 4x longer than a 5lb fire extinguisher.
Tested to work effectively in temperatures from -140F to +320F
11.75" x 1.2"
0.6 lb (230g.)
Makes no mess and leaves no residue
Clean and eco-friendly
Non-toxic
Zero thrust discharge: will not spread oil & liquid fires
Fights all major fire classes: A/B/C/K
Safe and maintenance free
Made in Italy
Click HERE for Element Fire Extinguishers
Click below for demonstration videos!
https://youtu.be/Zcx4vFNKjsQ
https://youtu.be/GwzZJInS40g
