Old 06-19-2018, 05:06 PM   #1
liquidimports84
o2 sensor question - code p0139
2001 Boxster
I had a p0139 error code. o2 sensor bank 1 sensor 2. Also my car hesitates on acceleration. I unplugged the sensor and plugged it back in and messed with a wire a bit. Hesitation got much better and the error code went away. Should I go ahead and replace the o2 sensor of should i investigate for injector leaks before i replace the sensor? Also if I should replace the sensor what is the part #? Before Starter Catalyst, Left or Right) or After Starter Catalyst?
liquidimports84 is offline   Reply With Quote
