Thread: coolant leak
Old 06-19-2018, 04:06 PM   #19
Geof3
Originally Posted by STRANGEPOLLY View Post
I also had similar problem solved w/updated cap 2004 S. Installed new water pump (twice)yesterday. 1st time I had folded up the gasket but knowing I'm a clutz I had ordered an extra. Flushed coolant system and installed new Tstat and housing. One new radiator hose and have a new motor mount but was not strong enough to break any of the bolts loose? Anyone else installing water pump for the first time should watch youtube video by Ben Burner for his "FRANKENWRENCH" works great for that one bolt you cant reach!!
Which bolts did you have trouble with? None of the bolts in question should have that much torque on them. The actual bolts through the rubber portion of the mount have a good amount of torque, but the mounts on the chassis, and on the motor shouldn't be too bad at all. The WP should be very easy overall, those bolts are just a few NM's.
