Brake Fluid Warning Light
Both the brake fluid warning light along with the PSM light are on. This occurred immediately after I disconnected the positive lead of the battery while installing a new amp for the stereo. Brake fluid is completely full, even slightly above the full line and has been that way for a year. I was working in the the front trunk passenger side and up under the dash. Anything I bumped or disconnected? I completely bypassed the factory amp wiring as well. My research so far indicates the PSM light is on only because the brake fluid light is on.
Suggestions on fixing this?
