Old 06-17-2018, 02:07 PM   #2
BYprodriver
BYprodriver's Avatar
Originally Posted by dlud View Post
Will injectors from a 2000 (return type fuel rail) work on a 2002 (non-return type fuel rail)?
Relatedly, is there any way to easily adapt the return type fuel rail from the 2000 to a non return 2002?
I have a brand new set of OEM 2000 injectors (and fuel rails) that I would like to use, if possible, in my 2002.
2002 injectors have 4 spray holes giving a better spray pattern. If I were you I would have the 2002 injectors pressure cleaned & tested & sell the 2000 set. Why risk a engine fire from leaking fuel?
