You may need to loosen the 3 main bolts on each side that attach to car and wiggle rearward and retighten. May need a third hand to reposition while you retighten. Had same issue when installing 03 top to 02 car. Also your tension cable with the ball/socket ends can be adjusted down to get rear edge of softtop down.
