These cars are at the bottom of the depreciation curve. An S will always be more desirable that a base in the long haul. Though, there are some features that make the 03-04 tempting. Dash configuration, and a few other things. The IMS is certainly something to consider, but keep in mind the actual failure rate is fairly low. Forums and the internet have created a true monster with the M96 engines. They all sound reasonable, and most likely will need things here and there. Drive them, buy the one that talks to you assuming the PPI is solid.
