Old 06-15-2018, 03:06 PM   #2
78F350
Motorist & Coffee Drinker
78F350's Avatar
Swapping the plug and coil is a good easy test. A compression check will help eliminate (or suggest) some possibilities. Compression testers are cheap and not too hard to do the check. Possibly the injector on 5. I've never had a bad injector, but i expect it can be swapped with another cylinder to check if you don't want to take them all to a shop.
