Old 06-15-2018, 07:31 AM   #1
TiberiusBoxster
I must have run 10 new bulbs through that socket. Intermittently it worked. Likewise power. I figured $50... and it worked.
Before I swapped the housing, and when first I began having problems with a couple other lights in that housing. I saw the parking bulb was out. Was receiving power. Replaced the bulb... all the tail lights worked... except for that intermittent bulb in the back.
You should have attached to the fuse-box housing cover on the inside... the fuses diagram. If not let me know and I'll post a pic.
Good luck.
I don't have the diagram on the inside, but I did find the one from Mike's website. I don't see one that says parking bulb though. Also, what housing did you replace? It sounds like it was in the tail light. Was it the socket where the bulb fit in? Did you just cut it off and put the new one on via heat shrinking or something?
Thanks,
2001 Boxster Base
TiberiusBoxster is offline   Reply With Quote
