Old 06-14-2018, 06:38 AM   #2
78F350
Motorist & Coffee Drinker
78F350's Avatar
Originally Posted by Geof3 View Post
... I don’t lower my top when it is cold (55deg or less), and if I am putting it in service mode in the winter, (I live in CO) I warm it first with a hair dryer....
+1
The 2001 owners manual says that "...below 0 degrees C. The rear window can break."
I cracked the window on a near perfect top by opening it on a sunny morning with a temp that was probably just below 50 F. I saw that it had a slight 'bad' crease starting, so I stopped and went to do the chop. Suddenly the slight crease became a 8" crack. That car (1999) has an aftermarket glass window top now.
I still have a 1999 with a plastic window and will not lower the top below 55 deg F.
