Old 06-12-2018, 08:17 AM   #5
Gilles
There are multiple sources of oil leaks on a Boxster and oil has an uncanny ability to leak in one place, run down, and then drip from somewhere else entirely.
The best way to find where the oil is coming from is to clean it up and then inspect it daily until you find the exact source.
+ 1 on Stone comments
First clean the engine thoroughly with engine degreaser and rinse it with "Low pressure" water and you should be able to identify the source of your leak
