I would recommend going to the Pelican Parts website and looking at the article on drain and refill the Tiptronic. I'm getting ready to do mine and I bought 10 quarts of Pentosin ATF and a filter kit. I think you're low on fluid! The procedure for draining and refilling are fairly lengthy and pretty specific. The car has to be level and COLD to drain all of the ATF. Then refill, start the car to get it into a specific temperature range and continue filling until the 9ish liters are in.
