Old 06-11-2018, 02:14 PM   #5
speedyspaghetti
Originally Posted by JamesD View Post
Have you had the front tracking/ alignment done? If not then it will be required. Some Meyle arms were found to be 6mm shorter than oem which makes this even more necessary. Did you tighten up the bolts that secure the bushings to the car/trailing arm once it was beck on thr ground and settled?
I jacked up the wheel carrier and then tightened it - I couldn't figure out a good way to get a wrench in there with the car on the ground. Any suggestions? No, I have not had the alignment done.
speedyspaghetti is offline   Reply With Quote
