Old 06-11-2018, 05:41 AM   #4337
Brian in Tucson
Originally Posted by Boatin View Post
Did my first oil change on the Boxster today. All went well until I started refilling with the new oil. After pouring a few litres in I had a look underneath and oil was dripping almost directly below the filling inlet in the boot. I got under and it was coming from a tube about 1/2 "which I think probably could be an overflow. Anyone had this happen to them ?
Cut open the old filter to check for metal fragments, clean as a whistle !
BTW Luv my Boxster
There are only 2 oil tubes that run from the "boot" to the engine. One is the big 2" filler tube and the other is the dipstick tube. Both are plastic and both tend to get very brittle. There's no overflow for oil, btw. I've worked on my engine and had both tubes break from age. Not expensive, but not real easy to replace.:ah:
I <3 my Boxster, too!
2001 Boxster
2007 Toyota Highlander
