Old 06-08-2018, 11:45 PM   #10
Cunningr
Cunningr's Avatar
I had the same thought. Maybe its just me, but there is no way I'd get under that car.
I have a four post lift. Before I get under it, I always lower the deck onto the fixed stops on the posts so there is an actual mechanical stop holding the deck/car rather than relying solely on hydraulic pressure. Then I place tall jack stands under both ends of the deck to hold it up in case the mechanical stops fail. You can never be too safe under a car.
Starter, kudos for attacking this job but please stay safe. If nothing else, do me a favor and throw some blocks in front of the front tires to keep the car from inadvertently rolling forward.
No, Inwrote it off as he gave it a good stability check and the photo makes it look worse the it is! Great shade tree mechanic pic for safety ad!
I dont see any choke under front tire, if you keep the angle you might add a chalk block for some extra safety.
Be safe brother!
