Thread: coolant leak
Old 06-08-2018, 11:32 AM   #13
pilut2
pilut2's Avatar
Thanks, NA. Hadn't considered that valve/o-rings as a wear item. Nice to know.
I had a similar coolant dump that was caused by a crimped o-ring in the pressure relief valve. I sourced a replacement locally for $5. As others have noted- it is a 5 minute job to take the valve apart to inspect the O-rings- there are two. Just be careful not to strip the screws when you re-assemble it.
1999 Boxster, Ocean Blue Metallic-grey top.
LN IMS dual row-, Ben's short shift kit
pilut2 is offline   Reply With Quote
