I have run 17x9 square many times in the past. I typically used the 10 spoke Oem Porsche rims with 55 offset. I run 15mm spacers front and rear with 255/40/17 71R tires. Camber is around 3-3.5 in front and 2.5 in the rear. Fenders are not rolled. No issues.
Note - I run camber plates and GT3 lower arms. I can tuck the tires in quite a bit in the well and have plenty of room between the fender lip and the outside tire. I can also do the opposite and extend my track if I want.
