Old 06-03-2018, 07:03 PM   #1
CrisZenithBlue
CrisZenithBlue's Avatar
Originally Posted by pilut2 View Post
Shortly after coming out of winter hibernation my CEL came on. Car is a 99 with 43,000 miles. Codes thrown were P1128 and P1130. The car was running well with the exception of a tiny stumble off of idle. I pulled the MAF and cleaned it but the codes showed as pending and CEL eventually came back. After searching the forum I learned that I could have among other things, a failing AOS (I believe that mine is original), a random vacuum leak - or a bad MAF. Since the MAF was simple to replace I started there. A couple of days later Amazon (by far the best pricing) delivered a new Bosch MAF and a new air filter. Problem solved!!! I passed my biannual emissions test yesterday. Idle is smooth and the little stumble is gone. I'm very pleased!!
can you tell me the part number on the MAF you got? maybe the amazon link?
been dealing with these two damn codes for too long. changed MAF 3 times.
CrisZenithBlue is offline   Reply With Quote
