Old 06-03-2018, 10:54 AM   #5
The Radium King
The Radium King's Avatar
well, i agree that thais car is most likely more show than go, but i'd argue with you on the stagger thing. no stagger may balance the car, but limits the amount of throttle you can put down on corner exit. 255 on the rear may be ok for a 200 hp spec racer, but for a beast you need more rear rubber. and you can offset that by adding more front rubber. what should be noted is that they've flared the front but not widened the front tires (if that's the case - i didn't watch the video). if so then more show than go for sure - flares to fit 235s? hell, i've widened my front track 15mm each side and am running 245s and still have room in the original fenders.
anyways, there is racing and there is spec racing. there is fast and there is spec fast. they are not mutually exclusive, but they are different.
