Old 06-02-2018, 12:56 AM   #1
chromecarz00
Window relays are in the immobilizer, so you likely have an immobilizer issue (usually caused by past or present water infiltration). Pull it, check connector pins and board for signs of water/corrosion.
Will do, thanks.
Also, I've been following your de-ambering threads for awhile! I figured I should do mechanical then cosmetic but I am ITCHING to get the amber off and the HIDs in.
chromecarz00 is offline   Reply With Quote
