Old 05-29-2018, 09:10 AM   #1
TiberiusBoxster
Pull the headlight out and test at the connector with a multimeter or test light.
Here is the pinout...notice that this is the headlight side, so reverse left to right for the car side connector:
If you're not getting power at the connector and the fuses are good, it is likely the headlight switch. They can be revived by spraying electrical contact cleaner inside the switch (spraying down the shaft will get some inside) and turning the switch back and forth. The contact inside can get carbon build up that creates too much resistance.
If the cleaner doesn't help, you may need a new switch.
PW, thank you for the quick response. I have read a lot of your posts on here and you seem very knowledgeable, especially with headlights. One question I had on your image, why is there a + and - low beam. Just want to make sure i understand all.
I will hopefully get a chance to check tonight. If not maybe tomorrow. I will post back and let you know what I find.
Thanks,
Chris
2001 Boxster Base
TiberiusBoxster is offline   Reply With Quote
