Old 05-28-2018, 11:58 PM   #2
particlewave
Originally Posted by Caeg View Post
I do have foam in the vents but from what I read, that only affects heat and not AC. I couldn’t find anything on both AC and heat not working so sorry if this was already posted.
Where did you read that nonsense?
Yes, it affects both and that is likely your issue.
Look through your center vent with a flash light and you'll see the heater core flap. Cycle from cold to hot and watch it to ensure that it has a full range of movement. If it does, fix your missing flap foam.
Interior vent debris
