Just a little more info I thought I would add. Tim Barber’s shop at Sonoma (TFB) did the setup. I thought I would give some of the details. They set it for a drivers weight of 170lbs, 40 psi in the tires, 3/4 of tank of fuel. The final corner weights for the car front l/r 760/716, rear l/r 915/861 Total weight of 3250 lbs. Cross: 50.1% with the driver. 13 clicks from zero on all four shocks. Final ride height is 4 7/8 inches front, 5 inches rear. They gave the primary and secondary angles but that is a lot to type in. I found it interesting so I thought I would share it.
