Thread: Spacers...
Old 05-28-2018, 03:57 PM   #13
tonythetiger
Will there be cake?
tonythetiger's Avatar
I'm not a rocket surgeon... but wouldn't the size of your wheel reveal if there's going to be rubbing or not? I'm running the stock 16s with 20mm spacers rear... 10mm front.
What size wheel you running? Did I miss something?
I went with ECS. Came with the extended bolts.
I have the original 18" twist wheels, stock tire size and want the wider stance. Not sure if 20mm spacers in the rear will introduce rubbing or not, hence the question.
It seems that 15mm are the most popular, which gets me thinking that wider might present an issue
