Old 05-28-2018, 07:13 AM   #8
oldskool73
oldskool73's Avatar
There's only 2 cables involved in the top :
* 98656171703 : 'Pliable Shaft / Cable for Cabrio hood.' ... one each side, run between the motor at the back and the transmission on the side. If these are broken or come loose your top (and clamshell) won't operate properly.
* 98656119102 : 'Cabriolet Hood Tension Rope.' ... one each side, connects from the rear hood bow to the body, helps hold tension the rear of the hood. If these are broken or not attached it won't really effect the hood operation, but the hood may look saggy at the rear, or knock over bumps.
oldskool73 is offline   Reply With Quote
