Thank you for the info. The wire colors and passenger location cut time off of this project for sure
In my case I was using XK-Glow LED strips which requires a positive trigger. I used a relay to do this.
Relay pole details are as follows:
86 (Input) - Negative (Brown w/ Yellow Stripe - Porsche sends negative as trigger)
85 - 12v +
87 - 12v +
30 (Output) - Positive Trigger (For me this was the XKGlow trigger wire from the controller)
Worked like a charm.
Hope this helps someone.
