Old 05-27-2018, 01:38 AM   #1
soxfan1966
Originally Posted by Geof3 View Post
Is it when you release the clutch, or does it squeak with the pedal out in general? If it squeaks when you release the clutch, particularly when warm, it’s either your spring, or the slave. Pretty common “issue” that’s really more of an annoyance than an issue.
It happens when the clutch is fully released, not as I'm releasing it. The video is with the clutch released (pedal out) but not in gear. Makes same noise in gear too.
soxfan1966 is offline   Reply With Quote
